1 - 3 of 3 Posts
I have an 04 tacoma, V6, ext cab. I have the Tuff Country 5" suspension lift installed. And I want to buy the DR ext travel coilovers with the Total Chaos upper control arms. Will these new parts work with my current setup? I've had a hard time finding a definitive answer. Can anyone say for sure if I can go ahead with this?
Thanks,
Cory.
Thanks,
Cory.
The extended travel coilovers only give a little extra travel, and yes, they will work fine on the TC lift with the new upper arms. This is basically what I have been running for quite some time now.
You may want to check my website, specifically the installation of the All-Pro upper arms. There was an issue of sorts with the slug adapter that replaces the upper ball joint. You may run into the same problem.
Thank you, Peter. Your web site is a real good resource. You helped with the 5" install last year!
Cory
1 - 3 of 3 Posts
