I have a Tuffcountry 5" lift kit brand new except its missing a few parts like the bolts/bushings bag, and the rear 4" blocks. it comes with most the bracketry, spindles, and ubolts. you can order the bolts bushings and brackets from tuff country and buy the blocks online for $30-$40. kit cost $1500new asking $800 OBO
it comes with :
55900-01 Driver Side Spindle
55900-02 Passenger Side Spindle
54900-02 Front upper strut spacers 2
54900-03 Driver side differential drop bracket
54900-04 Passenger side differential drop bracket
54900-07 One piece lower sub frame
54900-12 Driver side emergency brake cable extension bracket
52904BL Rear brake line
5U-243S 9/16” x 2 1/2” x 10 5/8” rear U-bolts (4)
you need :
54900-05 Driver side sway bar drop bracket
54900-06 Passenger side sway bar drop bracket
54900-09 Steering shaft extension bracket
54900-11 Passenger side rack and pinion support bracket
BL401 4” Rear lifted blocks
916NW 9/16” U-bolt high nuts and washers
54900NB Hardware bag
54900SL Poly and sleeve bag
54900INST Instruction sheet (this can be found on tuffcountry.com it has the list of parts included in the kit)
And if noone wants the kit the spindles work great with a procomp 4" lift so you can git rid of the spindle extentions that the procomp lift uses. check it out here http://www.parksoffroad.com/tacomamods/tcspindlesprocomplift/tcspindlesprocomplift.htm
it comes with :
you need :
And if noone wants the kit the spindles work great with a procomp 4" lift so you can git rid of the spindle extentions that the procomp lift uses. check it out here Installing Tuff Country knuckles onto a Pro-Comp lifted Tacoma will u take 400
it comes with :
you need :
Ill give you 400
