1 - 9 of 9 Posts
If I add two or three more leaves to the rear ones I have now, to get added lift and flex, would I need to install longer U-bolts at the same time. If so, where can I get longer ones.
i think all you would need to do is take a measurment of how thick the leaves are and see how much you have to work with.
im kinda looking for a good local source for some new ubolts myself because i've got some that are too wide and they don't really "hug" my leaves.
I was thinking about it an think I should be ok since I am probably going to remove my overload leaf. If they are too short I guess I'll have to run down to the spring shop. Thanks
· Administrator
When I added my AAL, I had enough length on the stock u-bolts, but that was it. I was going to add a block and bought new u-bolts from my local 4x4 shop, but ended up not needing them. Most 4x4 shops will have new u-bolts in stock. The ones I bought were a Rancho Suspension product.
USAFTaco said:
With my AAL I have a couple of threads left but I'm looking for some longer ones just to be safe. It would suck to go over a rock and leave your axle.
It would also suck to go over a rock and catch your longer U-bolts on rocks.
If you have two or more threads below the nut you'll be good, add some thread lock if your worried about loosening. ;)
Tim
· Long lost Taco Owner
Go buy some new ones. You will have a hard time getting off the old ones with out breaking them.
Thanks Guys, we'll see how it goes.
Selling Ubolts...
If anyone is intersted, I can sell ya pair of brand new ubolts from my FB lift. Already sold the blocks, so the ubolts are left.
FTS1500UBK-3 2.5" X 12" X 9/16" Square U-Bolt
Interested... shoot me a message!
1 - 9 of 9 Posts
