1 - 11 of 11 Posts
Hoist The Colors!
For anybody looking at having their injectors tested and cleaned, I recently took mine out of my 22RE to Engine Logics in Houston. What I found very helpful was that they offered a 'while you wait' service. The cost is pretty reasonable, $25 bucks per injector while you wait...$18 bucks per injector for next day. You can even ship your injectors to them if you live out of the area. The website for their injector service is www.injectorrx.com
Would you do this as maintenance or only if there was a problem?
You could do it for either depending how anal you are. It doesn't hurt depending on how hard your injectors are to get out. There's also Rc engineering here in Torrance (so cal) that sonic cleans and balances them with a print out for you and they are around 25 bucks a piece if I remember right. rceng.com
Hoist The Colors!
It wouldn't hurt to do them every so often. Unfortunately, I waited until there was a problem to take mine in.
Used them. good place.
What type of problem were you having?
X2
Tell me something about "springs" wearing out on the injector causing improper fuel delivery. Or gummed up injectors doing the same.
Does the computer compensate, thereby changing fuel trim values and ultimately causing a CEL. P0170 for example?
Hoist The Colors!
Lost compression in one cylinder and started having really bad blow back. Pulled the head and had a piston with a nice size hole in it. Was told this was typical of a fuel delivery problem. Pulled the injectors to have them tested and one had a severe flow problem.
Shannon, do they flow test as well as clean them. I was thinking about doing mine sooner or later.
Hoist The Colors!
Discussion Starter #10
Yeah, they test them first thing then tell you what's wrong with them. Then they clean them and then test them again. They will give you a print out of the results for before and after. They will even let you watch them test them.
Thanks for the info Shannon
sent from my Galaxy 2 Skyrocket
1 - 11 of 11 Posts
