21 - 39 of 39 Posts
Discussion Starter #21
Thanks!
I actually have one of those external speakers, but I haven't figured out where to mount it. I looked nice and small in the store, but huge in the cab...
Discussion Starter #22
Crossmember is welded in, bumper frame cut, hitch reciever tube welded into the main peice, tacked together.
Now comes the fun part of making a couple of legs and attaching it square, leveled and centered....
Discussion Starter #25
Got the reciever tube braced and end caps installed:
As it sits now:
And got new shoes!! :D
Looks great! Still thinking about how I want my rear bumper on Zilla. Is this new bumper on the Runner now? If so, post up some pics of the final product. I expect to end up with something similar on my '85 - the one you saw at Doug's.
Discussion Starter #29
Thanks John! Yeah, it's on the Runner now, I just realized last night I never posted final pictures.
Here's the leg design. I put 4 across the back comming down off of the new cross member and one on each side comming off the frame.
Couple of pics from the bottom. In the long run I think I'll go back and put a small rectangle of 3/16" plate over the side of the joint in the legs for additional strength.
Tailgate up:
Tailgate down:
It's got good clearance on the tailgate. The 4Runner gate is lower than the pickup gate, so I went with the angled legs to try and maxamize clearance. For comparison, see the picutres Volcom posted of his rig farther up in the thread. His is a 4Runner too, but he's swapped in a truck tailgate.
Doug and I actually talked about this design sitting under Zilla!
Here's how it sits on my rig:
And a couple of shots from Moab for better perspecive:
I'm pretty happy with the way it turned out. I was in too much of a hurry when I finally attached it to the rig, and I wish it was a little more level on the body rather than sloping away to the back. I've also decided that those outside corners need to be turned in to 45* angles, but I need to determine exactly where the tire carrier is going to sit before doing that.
Moderator
I'm not sure if you noted it above or not, but it should be said that you built the bumper keeping in mind and trying to plan for a future tire carrier. That's why it sits so far out.
Looks solid! Did you drag the hell out of it and give it a good test in Moab? Every time I go there my back bumper on the D-cab gets some heavy abuse. :D Thanks for the pics! I think I'll 45 the corners when the time comes but the rest looks good and stout to me!
Discussion Starter #32
Thanks! Yeah, it drags more than would be ideal, but I think re-working my rear suspension will help that a bit. After putting that bumper on and hauling camping gear out to Moab my rear springs are sagged out again.
I just scraped it on Fin's and Hell's, but I dug it in hard trying to get up Z-turn on Moab Rim.
:bump: for updates on the build. What is the status of your build on this thing now? Did you ever beef it up to take it from :doh: to :boobies: so that I can :clap: ???
Everyone else in Colorado is building their rigs for bigger trails... You might as well do it now if you haven't already. Because you will some day anyway. ;)
Discussion Starter #35
Alright, I'll come out of hiding for a minute.
I think its more :dunno: than :boobies: at the moment...
After about a 2 year delay, the tire carrier is installed:
I used RuffStuff's spindle and mounting plate, frame is 2x2 .120 wall. At least on the road I've got more useful visibility out the back than when I had the spare lashed to the roll bar since I can actually see out of both corners of the window now.
I also cut the bumper corners back to gain some clearance:
And I'm currently working on the rear suspension; installing 2" lift, medium load OME springs and shocks and doing a U-bolt flip with RuffStuff's plates and bolts.
Moderator
Runner looks great in person now, with the tire carrier and rear lift on. Not as much ass dragging will be done.
Discussion Starter #37
New rear suspension is installed; it's sitting 4" - 4.5" higher than it was on the old springs.
It looks a lot better now, and from driving it around town some it doesn't feel overly stiff. Looking forward to getting it out and running some trail next week! :driving:
Discussion Starter #39
Yes it does: much less ass-dragging, supported all of my camping gear better and still seemed nice and flexy on the trail. I need to run it into the garage to see how much the springs have settled in.
21 - 39 of 39 Posts
