1 - 14 of 14 Posts
http://www.rallylights.com/SMS_Custom_Wiring_Harnesses.aspx
• Most Asian (Switched Ground) Vehicles where the stock bulb type is being maintained.
• Most Asian (Switched Ground) Vehicles where the stock bulb type is being Changed.
SUV's site has been down for a while and have not returned my emails.
Which one do I pick.. and also which configuration do I pick? I just want brighter bulbs non HID.
-Thanks SafetyDang
they won't be that much 'brighter' with the new harness but they will last longer. Will you be able to see a difference? yes, but don't expect the output of a 100w bulb ;)
check Daniel Stern's site...he may be back in the country by now.
Thanks for the info Hytenor.
Hey SafetyDang did you end up getting a new headlight wiring harness? if so which one, i am looking at upgrading my wiring harness too and all the otehr threads i have found are old and suvlights.com isnt up or returning any of my emails aswell. Let me what what you did and if you saw an improvement! Thanks!
^x2
truck ~n~ tow
4crawler lists one on their site...
http://4crawler.com/4x4/CheapTricks/Headlights.shtml#OnLineOrdering
after installation... even with oem bulbs...
you will notice an improved light output.
maybe 10 - 15% (tho' I haven't measured that)
Better then that...
you will find that bulb life lasts much longer.
My oem type bulbs were still going strong...
after 8 years of use.
Recently upgraded to HO 90/100W bulbs...
and the upgraded harness doesn't even get warm to the touch.
I'd recommend this upgrade to anyone looking to
improve light output as well as longer bulb life.
* edit:
just noticed that the 4crawler site is listed as out of stock...
so... some others...
http://www.streetbeatcustoms.com/ADS/Wire-Harness/9004-Headlight-Heavy-Duty-Wire-Harness-Relay/532242/
http://www.headlightservices.com/Wiring.html
It's really simple...
google "headlight upgrade harness Toyota Tacoma"
and one should see their options
1st gen tacos (mine is an 03) use switched ground correct? and we use the9004 harness too right?
i have some you might be interested in.
i run PIAA intense white bulbs along with the harness; makes me smile.
looks just like this-
one is new in package and one is used.
let a honkey know.
I sent Daniel Stern an email to see if he's still selling them
Discussion Starter #13
I have not and totally forgot about this.... But....
let a honkey know.
PM Sent
I will :D
Daniel got back to me. He's still making harnesses if you guys are still looking for them. These are not cheap factory made stuff with 16-14g wire ;)
email him here: just change the (at) to @
tech(at)danielsternlighting.com
1 - 14 of 14 Posts
