hi,
i was just wondering if anybody knew what could possibly cause a slight vibration in the front end of the truck after you lift it. Is this normal :confused: ? Could it be the tires or an internal issue within the front end suspension system. Right now i'm just running stock 265/70/16 tires on it and i have a 3 in. spacers on the front. Can anybody help?
Have you had an alignment yet? You would most likely need one after the lift; and that could cause the vibration. If you're going to be upgrading tires soon, you could hold off till they are installed; otherwise id get an alignment asap.
-chris
that's what i thought it would be too, but i already got an alignment and the vibration is still there.
Seems some taco's are more sensitive to this than others, but the trucks with ADD are known to vibrate when lifted over 2-1/2 inches. Not all do it, and some vibrate pretty steadily. It is due to the shafts not disconnecting, and spinning constantly. One of the reasons guys switch to manual hubs. I am at 2-3/4. No vibes. At 3" solid, I sart to buzz on the highway. I don't know how you take out a little from a spacer... machine shop, or bandsaw would be my guesses.
Not sure if your 4wd or not but if so Id check the front driveshaft. Same thing happened to me when I built my rockcrawler. No problems before lifted but after I had a vibration. Took out the driveshaft to check ujoints and they were all pretty toasted. Just an idea.
