Thinking its my u joints the driveline has a little play in it so im thinking its the u joints causing the vibration when i let off the gas. What do yall think?
When my u-joint went bad, it was the opposite - vibration would go away after I let off the gas. :dunno:
well that kinda kills my theroy then lol i just figured because the torque was taken off the driveline that it was free to shake when its not under throttle...
I was thinking vibration when let off gas was pinion or carrier bearing(s)? I've heard one is gas and one is coast, but I forget exact which.
wow, i just ran into this today with my buddies jeep grand cherokee.
his full time 4wd and it makes noise and shakes as soon as he lets off the pedal. i know his u joints are good cause we thought that was the problem and replaced all of them today.
pinion or carrier that sounds about right but i dont remember wich one.
u kow i have a 94 auto. and my t-case makes the same noise u r describing. but when i press it forward it goes away like the t-case lever is loose or somthing.
