1 - 2 of 2 Posts
Hey guys,
I just wanted to let you know that my Warn XD9000 died on me while winching. I sent it in to the authorized service center (http://ttora.com/forum/showthread.php?t=53641), and although I am still not 100% sure as to what the original problem was, they are fixing it under warranty. They told me that the way the XD9000 sits in the ARB front bumper does not allow water to drain from the motor. I had also overclocked my gearbox to make the clutch more accessible (a tiny bit more than what ARB had stated I should do), which they said was very bad. I just wanted to give you all a heads up!
white_eskimo said:
Hey guys,
water won't drain from those things no matter how you mount them. If you do a lot of water crossings you have to rebuild just about any winch on a yearly basis....that's part of the game ;)
they are not hard to rebuild, ie, disassemble, regrease and reassemble... Takes a couple hrs unless you find some corrsion.
Mine (and many others on rigs I wheel with) are mounted flat and we all have this problem. They are NOT water proof, never were.
1 - 2 of 2 Posts
