I need some help kicking the idle up on my truck and the only screw i find doesnt seem to effect idle. Any ideas on getting my truck to idle a bit higher? It runs pretty good but just needs to idle a bit higher for leaning and climbing.
Wow, I don't rember what screw does that. It's been 10 years, the last time that I had the 32,63 webber. I though it was the only screw on the linkage. The one on the side of the carb was the mixture screw.
It's been a while for me too, but if I saw the carb might remember. Seems like the idle speed was in the back maybe?
IIRC there were only two screws on it. One is air/fuel, the other is idle speed.
Check the timing too, Russel!
I never found a screw so i just tightened up the cable a bit and it works for now. Im swapping it out with a carb with deeper bowls cause as some of you guys saw wheeling my truck hates rocks and tippy stuff. I was told by the PO it is more of a street carb so were trading out for the offroad one so i can wheel while i finish my motor. 22r/20r efi ftw!
