Were can i find NLGI No.2 Lithium and molybdenum disulfide lithium base grease? Are there any picticular manufactures that you recommend or are they all the same? Thanks.
Molly B can be found at any auto parts store. Unless your really picky most any brand will work, if it's Molly B the chemical make -up will be about the same from manufacturer to manufacturer.
Sta-Lube brand has a moly in a lithium base grease. In principle a manufacturer can add molybdenum disulphide to grease of any base, but I expect Tim is right in that any moly grease you will find in an auto parts store will probably be lithium based.
