1 - 3 of 3 Posts
If this is the in the wrong section I appologize in advanced. Just wanted to know what these things are worth...
a set of manual hub spindles one with a total chaos spindle gusset, one without both have the upper ball joint pressed out (id assume these would be worth some $, considering people always convert to manual hubs)
1 working stock cv axle (manual hub)
1 stock cv axle with the inner cv assembly missing (manual hub)
Are the wheel bearing in good shape, that will make all the difference..Working Cv axle, $50, as far as the other one goes probably not much.
one side the bearings are good for sure (just came off my truck recently and worked fine) the otherside has been off for a while but im pretty positive its fine (will of course confirm before selling). have about 70k miles?
1 - 3 of 3 Posts
