running 16x8s 3 3/8" BS w/ 285s, anywhere near that should be fine.jtaco1 said:I am looking at getting 16x8 rims to go along with the 285/75 tires I have. They will be going on a 99 and I don't want them to interfere with the upeer A-arm or the frame. I have 5 inches of lift. So what's everybody got?
3.75"-4.25" will work; it depends on how far you want them to stick out.jtaco1 said:I am looking at getting 16x8 rims to go along with the 285/75 tires I have. They will be going on a 99 and I don't want them to interfere with the upeer A-arm or the frame. I have 5 inches of lift. So what's everybody got?
So you would say about 3.75 or so.avc8130 said:I had 4", as I think you know. If I was doing it again, I would have gone a little less to get a little more width out of the truck. Helps with handling!
Anthony
less backspacing (smaller #), makes the tires stick out further, requires more lift to clear the fenders and adds more wear and tear to the suspension and especially the steering components.cauch235 said:which sticks out farther... the smaller number or the bigger number.... like 3.75-4?
Same Here, no rubbin' except a little shiny spot on the drivers side frame rail.KStacoma said:I'm running 15x8's 3.75"backspacing w/33x12.5 mt/r's no rub.
Not necesarily, the rim size doesn't matter on backspacing whether it's a 15 or a 16, it's the depth that matters like a 15x8 or 15x10. It also depends how far you want to push the tire from the a-arm etc. but if you push it too far out it will rub on the frame at full lock and cause increased wear on front end parts since backspacing acts similar to a wheel spacer when it comes to how it wears things out.jtaco1 said:Thanks guys, so it seems that if you run a 15x8 use the 3.75 and if you run 16x8 run 4 inches of backspacing.
Just curious. What is your lift increment, and what suspension are you running?KStacoma said:I'm running 15x8's 3.75"backspacing w/33x12.5 mt/r's no rub.
In general, 33x12.50s require 5-6" of lift to really 'clear' them. Some still rub even with 6" of lift. If you are willing to do some sawzall trimming and hammering you can technically make them work with 3" or so depending on the type/brand of lift.Ritchie said:Just curious. What is your lift increment, and what suspension are you running?
I have an '03 Tacoma reg cab prerunner 2wd and would like to run 33x12.50x15s.
Hytenor,hytenor said:In general, 33x12.50s require 5-6" of lift to really 'clear' them. Some still rub even with 6" of lift. If you are willing to do some sawzall trimming and hammering you can technically make them work with 3" or so depending on the type/brand of lift.
and then theres the needed regearing![]()
If you have 12.50s you can't be running 4.5" backspacing...won't workVernon29RW said:Hytenor,
Just wondering how those 4.88's work with the 2.7. i have a '98 with 33x12.50's and haven't regeared yet. Its not the ideal mpg/power setup in the world! I just didn't know how far down the list of gears I have to go to get my power back and maybe a litle more, but if 4.88's work well with 33's then that is great. Also to coment on this thread a little more. I have Old Man Emu's with a 2" BL and i don't have any problems with rubbing either on road or off so that's only about 4.25-4.5" of lift and it works fine.
I don't even want to know, LOL04RedLobster said:wow you must of spent a lot of money changing gear to gear![]()
