1 - 11 of 11 Posts
gearbox said:
I'm having some sliders made and I thought I wanted Grade 8. Thinking about it I probably want something with less stretch. What should it be? Grade 7 zinc-plated?
G8 will be fine. Why do you want it to strech!? If you are breaking/bending/streching a G8 bolt on your sliders... you have other issues. The bolts just clamp the slider to the truck, the design bears the weight.
Going to a lower grade will increase the chance of it stretching. Either way, I doubt you would stretch or break a G5 or G8 bolt with a properly designed bolt on slider.
Determining Bolt Grade
Bolts of different grades are marked on the head to show what grade bolt they are.
Grade 2
Grade 2 is a standard hardware grade steel. This is the most common grade of steel fastener and is the least expensive. Grade 2 bolts have no head marking (sometimes a manufacturer mark is present).
Grade 5
Grade 5 bolts are hardened to increase strength and are the most common bolts found in automotive applications. Grade 5 bolts have 3 evenly spaced radial lines on the head.
Grade 8
Grade 8 bolts have been hardened more than grade 5 bolts. Thus they are stronger and are used in demanding applications such as automotive suspensions. Grade 8 bolts have 6 evenly spaced radial lines on the head.
The higher grade, the more the fastener has been hardened, it stronger, but more brittle, and thus less stretch. A G8 will withstand more pressure before shearing/breaking but will not stretch as much because it is harder. And thus a G7 will yield more strech than a G8.
more info http://www.raskcycle.com/techtip/webdoc14.html
Shouldn't need G8. G5 is fine for that app.
in theautomotive world, just dont go less than grade 5 sae, or 8.8 metric.....
sae 8 is fine... you arent going to see he forces to have issues with a 5 or 8
· Premium Member
Yep. Lesser grades stretch before they fail.
Grade 8 bolts are more brittle and just pop when they go...
Depends on the design. I could have used Grade 5 on my sliders, because the bolts are there only to hold the sliders in place. The sliders apply all the force to the frame, not to the bolts.
But I still used Grade 8 fine thread. Why not? Because I can...
1 - 11 of 11 Posts
