Hi there, i am a new member to this site and a new proud owner of a 2006 Tacoma doublecab prerunner LB. Its my first toyota and my first truck and i love it. But now i want to add some parts and one of those is a liftkit. I want a lift not extremely expensive, between 3 and 5in., and i like the look when the tires stick out a few in. Please tell me what would work best and look the best. Thank you, your comment is greatly appreciated !!!!
P.S. Could you also tell me what size tires and rims i should put on it.
Which do you want? The best or a 3" to 5" lift and wheels that make your tires stick out?
Do a search for God's sake.
you could go with a simple revetek 3in spacer kit, with some 32s or you can go with a full bracket kit for 35s, and you can do coilovers. and set them to about a 3in lift to fit 32s, i think you can fit 33s with trimming, but i dont have one...yet.:D
As far as rims you have to go 16'' or bigger. If money isn't an issue....buy doetsch tech or camburgs or donahoes for the coilovers. Crank em to about 2.5'' and put some 32s or 33s under it. You might have to get a grinder or hammer in the pinch weld. Will you be wheeling, or using this for looks, if so revtek spacers will be fine. Just remember that if you use the spacers and wheel often, you put to much strain on the control arms and if you crank the coilovers up to much you put the cv axles at to high of an angle. However there are a couple of members here who use spacers and have had them for 3 years and have had no problems.
For future questions such as these, use the search feature, it will answer all of the questions you have. Also, post this in the noob forum if you are just to incompetent to use the search feature.
Camburg/SAW 2.0's with 0-3.0" of lift
If you want the wheels to stick out get less backspacing on the wheels
Go with 285/70/17 for tire with 4.0BS on the wheel, that should do the trick
I wouldnt suggest 17" wheel/tire combo if youre gonna offroad, because the price diff b/t 16" and 17" is big. A 17" tire is significantly more expensive than a 16" tire. I learned by lesson :cool:
