any longer shock will have both. so if you have a 8" travel shock now a new 10" travel shock will "give" you both (typically).
the real issue is where the shock starts from which is due to oem mounting. so a new 10" will most likely bottom out in compression before bump stops do. on the flip side, your leaf extension will be greater.
