I am pulling the front diff for gears this weekend, and need to pull the driveshafts. I don't have the right size socket to remove the outer axle lock nut.
Anyone know what size it is.
2002 double cab TRD 4x4
Thanks in advance
wut?
Thanks in advance
35mm............
I hope the chances of me getting one of those in Craftsman is OK tomorrow. I was wondering if I was going to have better luck finding a SAE similar size like 1 3/8 would work?
try homedepot they had a 35. a 36 will also work as noted by someone else.
i think the torque is 100+ so i don't think a standard work be a good idea unless it is the same... say a 19mm and a 3/4".
Totally right info in the replys. Thanks
I couldn't find a 35mm or a 1 3/8 at either 2 places I went too. But I did find that Home Depot was closing out its individual sockets, and the 36mm was $2.00!! Last one on the shelf. Worked good enough. No stripping, but a little sloppy.
35 mm socket
Thanks in advance
Not Craftsman , but I think it'll work!
