I had a 4" Superlift system installed about 4 months ago and had confidence in the installer since then had some work done on another truck and my confidence has been killed. Does anyone have a pic or can anyone give me an idea where the A-arms should be? If you look at the IFS box meet the lower control arms are almost at a 90 degree angle the cv's are straight out. I'm not sure if the torsion bars are adjusted enough or not ... hmmmmm? as for the rear I have aal and 2" lift shackles " if I can adjust the torsion bar and maintain good ride I have a set of 1" lift blocks I can install to even it up.
Aaron
it would help if you posted some pics
I'm only commenting out of pity. I installed a fabtech 6" on my old '02 f150. I doubt my results would help you. For what it's worth, I adjusted the torsion bars back to the stock tension by counting the number of turns on the adjusting bolts on each side when I removed them during the install. The LCA's and the axle shafts were at a bit more of an angle than stock once I was done. Couldn't tell you by how much, but is wasn't much more.
