1 - 17 of 17 Posts
Daily driving but still wheeling it as much as I can, daily driving consist of to and from work(20-30 miles daily) wheeling consists of snow when there is some and rocks mostly and very rarely mud(not bogging or anything)
Would like to run MTRs they are a little more on the expensive side...then thinking iroks but they wear too fast
I really like the MTRs...are there any other tires similar that still keep a narrow look to them?
I will running a 37-38" tire...I have a 16.5" rim so I'd have to get new rims of I got MTRs...
16.5" width or is that the tire size?
if you are running that wide wheel your tire choices will be limited.
or...you are running 8-lug Ford wheels on full-size axles?
No rim height is 16.5, width is 9 or 10 I think.
Yeah 8 lug full size axles
Heard they don't air down well...?
never had a problem down to 10psi w/o beadlocks.
gonna fine out how they do at 2psi ...w/beadlocks...in the snow tomorrow :D
Ive seen that scuba has aired his down pretty low and they have held up fine
wow im super jealous, let me know how they do!
tires hooked up great in the snow...once I dropped them to 0psi :p
I started out around 8psi but once we got into 3' of powder to push through it qickly became obvious that wasn't nearly low enough. I got lazy and just let them piss air until they stopped and ran completely flat. The truck was able to plow though a lot of stuff that other rigs there could not do. I did get some interesting looks from others, however :p "uh, do you know your tries are flat?" Once we got back into the packed snow I had to add air...ride was a joke and couldn't steer easily even with hydro assist...my PS pump was screaming!
The next time I'll try getting a closer estimate on actual psi and not let them get quite that flat.
Others in the group dropped down as low as 6psi w/o beadlocks and no one lost a bead. I think Phil was down to 2-3 with his beadlocks.
Discussion Starter #15
did you guys get any pictures out in the snow?
waiting for others to post pics. i only got some video on my Contour dash cam that I'm still sifting through.
1 - 17 of 17 Posts
