If you're not in it for super harsh going, and want a little lift with a bilstien, Call Downey off road, or downey offroad.com. They use a large body rebuildable bilstien, and have a 600lb spring on them. They are easy to install yourself, and cost a little less than most other setups. I have had them for a while, the spring is for sure firmer, and the shock action is way better than stock. Mine will be up to bat soon, long travel kit is comin' after the new year.... also, check with a guy on this forum named Demello. He has a shop, and does lots of swayaway setups, which are the most affordable of the aluminum bodied coilovers. Either way, they beat the fabtech kit, which is NOT rebuildable. Good luck.
