1 - 8 of 8 Posts
hey everyone. Can the stock u-bolts be used with the OME lift springs in the rear? my old ones are pretty rusty and i'd rather just get a new set of stock ones unless they won't fit with the taller springs. does anyone know?
· Re-Member 9/11
The ones that came with mine from www.wheelersoffroad.com were quite a bit longer than stock, and hung down probably 1.5" after being tightened.
Bill
As long as the new pack is in fact taller then the factory pack you should be fine.
I didn't measure it, but my 7-leaf Deaver isn't quite as tall as the factory pack. Due to the corrosion on the U-bolts I was never able to really tighten them down enough.
cool - sounds like the stock ones (or new ones from the Dealer) will work. Thanks. :)
I just got a new set from Wheelers for $27 shipped to my door. THey are longer, but hit them with the saw and no problems.
1 - 8 of 8 Posts
