i don't think much will fit behind there, i haven't actually took off the cushion part in the back, but the plastic peice comes out fairly easy and it looks like it goes to the back of the sheet metal. im not sureakshunj said:The little padded piece above the fold down seats in the xtracab. Is there any room behind it? Looking for a place to hide my eq's which, length and width wise will fit there but I do not know the depth.
There is no room behind it, you can run wires thats about it. but nothing taller than a 1/2 will fit behind there. The cab isnt double walled back there, the only place its double walled is the A/B/C and even those are shitty, i should know mine are all falling apart!akshunj said:So the sheet metal seems to be double walled and bubbles out to meet the cushion?
David, try again.Tankota said:I think they are just bolted on there - I do belive the back metal is double walled though, so in theory you could do a cut out behind them and have some room.. I just checked the FSM, it is just bolted to the back metal of the truck, the top plastic piece comes off and the bolts are under it. I'd upload the PDF but this board only allows 19k, and it's 30k.
Can someone with the FSM or experience tell me what the heck is beneath the drivers side rear seat? If it's just empty space, surely it could be used for something.Tankota said:I think they are just bolted on there - I do belive the back metal is double walled though, so in theory you could do a cut out behind them and have some room.. I just checked the FSM, it is just bolted to the back metal of the truck, the top plastic piece comes off and the bolts are under it. I'd upload the PDF but this board only allows 19k, and it's 30k.
the whole thing is a cubby hole. its a bolted on sheetmetal seat, the whole rear bench is only 4 bolts holding it together.Jamier2 said:Can someone with the FSM or experience tell me what the heck is beneath the drivers side rear seat? If it's just empty space, surely it could be used for something.
No, like I said under the drivers side rear seat, not in the center.akshunj said:Do you mean where the jack and tire iron are stored in the cubby hole? If you mean under the hump in the sheetmetal that is for the tranny/transfercase.
If you have the FSM pages, could you email them to me? The email is jamier at insightbb dot com.DesertTRD said:the whole thing is a cubby hole. its a bolted on sheetmetal seat, the whole rear bench is only 4 bolts holding it together.
I see what you mean. Like Corey said, it's just a few bolts holding it on.Jamier2 said:If you have the FSM pages, could you email them to me? The email is jamier at insightbb dot com.
Thanks,
Jamie
