Alright, this isnt a typical quesiton about what wheel width to get, it's more along the lines of what tire can I fit on a 15x6 wheel. I have heard some of the traditional "guidlines" somewhat. I have been told that it's not recommended even placing a 31x1050 on a 15x6 rim because it's too narrow of a rim. Well, I have done that and it's no problem personally.
Now im wondering can I fit a 33x1050 or 32x1050 on a 15x6 rim. On the tire manufacture's website they usually suggest a larger size rim. Like on bridgestones site the "measuring rim" is a 15x8.5 for a 31x1050. Interco actually was using a 15x7 for their 32x1050. So im figuring that I can get a 33x1050 (which is only .5" taller than the 32x1050 from interco) on a 15x6 rim with out much of an issue.
Any thoughts? Dont ask why im going with Interco here, they are cheap (well more so than BFG) and wear nice in my personal experiance. Well, nice being relative to life, not luxury. Had a pair of TSL radials on my friends PU and they lasted a bit more than 45K, maybe more since the odometer was off
· Premium Member
It is not the height that matters, its the width.
The problems with running a wide tire on a narrow rim are 1) by squeezing the bead in to the rim width it will cause the tire to "crown) or bulge in the middle of the tread causing uneven wear and short tire life, and 2) the tire is MUCH more likely to pop off the bead especially if under inflated....
Oh yeah, and your tire selection will look alot better mounted on an 8" wide wheel!!!
So since height isnt what matters, a 31x1050 would have the same issue with wanting to pop off? Odd cause I never had any issues with my 31x1050s on that rim on my 4runner. Keep in mind im not going for stance here. Im going for a nice tall tire without rubbing or a 6"+ lift
· Premium Member
He should be fine, shouldn't he? A 10.50 on a 6" is no different than a 12.50 on an 8". The same 4" difference. You should be fine w/ a 33x10.50.
· Premium Member
Here's what they (33x10.50) look like on a 7" wheel..Follow the link to my pics just below
