1 - 17 of 17 Posts
i am getting a coilover/deaver/bilstein setup in the near future and i am hoping to put a 3" bl on it also.... what size rims and tires would you suggest and what brands... for rims i want a classic look like the mickey thompson classic II or something like that... for tires i want an agressive look with off-road and street durability and low wear...thanks
I have the OME setup on mine along with the 3 inch body, and am putting on 16x8 rims, similar to what you want, with 4 inches back spacing with 285/75 Goodyear MT/R's.
Should be nice when done. :)
you should be good with 33x12.5's with some trimming. the MT classic II's look good, i'll probably get a set of them when i get tired of the black steelies. As far as tires, some of my favotires are MT baja claws, BFG MT's and Goodyear MT/R's...all depends on what typre of wheeling you'll do
I'll agree with YoTracer I have BFG MT's wrapped around Mickey Thompson classic II's. I think its a pretty good look.
good luck with whatever you choose
when you say trimming what do you mean? would the 33's look small with about 5" of lift? i will most likely have the coilovers set at 2-2.5 and another 3 on top of that...
by trimming he means the pinchweld mod and 5" of lift looks good with 33s...a lot of people actually run around 6" but others run 3", 5-6" is the recommended lift for 33s with little rubbing.
like he said, you'll need to hammer down the pinch weld, and 33's will look good
pinch weld?
what is a pinch weld???? sorry i am clueless....
33's
Hey man,
depending on what brand tire, and what the backspacing on the rim, you shouldn't rub bad or AT ALL. However, we all know swampers run a lil large, so you would more than likely rub w/ those. Anyways, 33x12.50's on 15x10's would look excellent. I'd go w/ either a BFG MT or AT mainly b/c of the life span factor. Good luck, Wes
I'd stick with 15x8's...15x10's will be more prone to rub, and wont hold the bead as well when aired down
I guess nobody talks about them since they are new, but i LOVE my Firestone Destination M/T's. Great wear, AWESOME looks, Great grippage!
Kuhmo Venture M/T's all the way. They're around 80 bucks for 31's, nice agressive pattern and excellent tread wear. I commute 50 miles a day and only mud once a week and I'd buy em again in a second.
Discussion Starter · #16 ·
I would personally go with the 3" revtek and a custom 12 in susp lift. you would def. be able to clear any tires you are currently worried about...
:bump:
1 - 17 of 17 Posts
