Looks like a knock sensor or possible oil pressure switch. Pic of where it came from?
i need the connector for it. The problem is that it is a single pole sensor but a two wire connector with a green/red wire and a green/white wire.
So it is in fact the knock sensor. I went ahead and traced the two wires back to the ECU and they were for the old IFS 4wd system from before the solid axle swap. I then removed the intake manifold and sure enough the knock sensor wire/connector were hidden somewhere between the manifold halves.
Glad you figured it out. Definitely a knock sensor from the location photo. Glad you found the other wires... It should be pretty straight forward from there.
