I'm looking into a shop press to be able to do my own axles, gears, and about anything else that I need to press. I can get a sweet deal on a 12 ton but I'm not sure if that is enough. The 20 or 40 ton presses are much more though. Has anyone found that a 12 isn't enough. It would do everything from bending to bearings, but I don't want to invest in the wrong tool. Of course bigger is better, but is it necessary? Thanx
What's the price difference you're looking at? I honestly can't remember the size the shop I worked in had... never used it much. I always used the mechanical hand press when I could.
That being said, I've never regretted buying something more powerfull than I needed at the time.
· The Satanic Panic
id go with the heavier ton, cuz itll suck if u have to press something thats beyond the limit of the 12, its better in the long run to have more than not enough and pissed off about it
· Long lost Taco Owner
If you ever want to do tacoma wheel bearings, the 12 ton one is not going to cut it.
