i keep blowing EFI fuses and con't figure out what is either going bad or shorting out. nothing is burnt or cut.
I looked into this for somebody a while ago. The cause almost every time was that the O2 wire was melted on the exhaust. I know you said nothing is burnt or cut but I thought I'd pass that along in case it deserves a closer look.
if youa re blowing EFI fuses.....something IS shorted
i appriciate the help but, no sh*t.
the one thing i am gonna look into further is grounds, specificly the one's connected to the engine. and yes i looked at the O2's and nothing is melted.
bust out the wiring diagram and start from there..not the groudns
yea, i've looked all over and can't find anything and i've heard a bad ground will cause voltage spikes. i can't find the link to the wire diagram, and right now i am fighting with my son so i will look later.
Go get yourself a FSM... and start troubleshooting. You obviously have a short somewhere. it's very difficult to troubleshoot from thousands of miles away. Find out where that circuit feeds the +12VDC and go from there. You can measure the resistance of each circuit. When you read 0(ish) Ohms, Then you are on the right track.
