this has been bugging me for a while. my drivers side door window rattles when rolled all the way down. anyone have a solution or tsb for this?
· Premium Member
this happened to me when my truck was new... take it to the dealer. its a warranty thing. the factory didnt tighten a bolt and the bracket that keeps the window in place is loose. took them a good 2 hours to actually fix it but i didnt have to pay.
Mine did this too when I bought it used at the dealer.
I took it back for th emto fix, and 8 mos later, it broke again.
I guess there is a part on the bottom of the regulator that can break or come loose...
Heres the TSB:
Get it while you can....I'll be taking it off my site soon....
Its TSB BO-0013....you can go to any Toy dealer, and theyshould be able to print it out for you...
http://www.frontiernet.net/~toyfvr/TacomaTSB2.pdf
i hope that is all it is. my window rattled and i never got around to fixing it for awhile, but when i did i found that only one of the three bolts that held the motor to the door was still attached. major problems, bent up the window regulator, burned out the motor which in turn shorted out the master switch. time and parts 400+. so be extra careful.
