1 - 20 of 20 Posts
Any one have a cheap trick for replacement? Mine is brittle and crumbling apart.
Toyota wants $100 and there are no Tacoma parts in the junkyard here.
I can eventually figure something out, I just wondered if someone here had a good idea.
Thanks.
My friend suggested a Gatorade bottle. Building one might be best, unless I find one in someones broken truck. $100 bucks ain't happening.
Ive seen them built out of PVC pipe before
It's just a resivoir so even something like a gallon milk bottle will work. All you have to do is mount it somewhere.
I ran out of room under the hood so put a Samuri washer jug in my front bumper and ran some kitchen sink drian pipe out the top of the bumper to fill it. Use your imagination.
Nalgene bottle works great.
Had the same problem, reservoir looked like a dropped hard boiled egg with chunks breaking off. Not sure the Gatorade or a milk jug would hold up for long but Nalgene would be better. Several PVC pipe ideas online you could design for capacity, space issues, or both.
I haven't solved this myself yet but was looking at LMC Truck for another vehicle. They have a cheapo looking universal kit (1.5L $19 part #36-4083) which I don't like but I'm going to go with #37-4020 that looks like a better match for me.
I wonder what kind of shitty plastic Toyota is using for those things. You'd think it'd be easy to make em last pretty near forever. I was using the original neck and cap for my front bumper bottle thing but the plastic they used rotted away so I replaced it with ABS drain pipe.
My stock 2003 2wd Tacoma, washer reservoir has pump and sensor, local Toyota dealer quoted me $180 for reservoir. I checked Toyota of Dallas Parts, prices for reservoir for your and my Tacoma are $82.39, but not including shipping.;)
I did a pvc neck on mine, epoxied it to the stock tank and used a pvc cap. The stock filter screen fits perfectly in the pvc pipe while still allowing the cap to go on.
I'd find a tank that fits and epoxy a pvc pipe to it.
Discussion Starter #11
That sounds good.
Just the filler neck on mine was bad. I took it out and wrapped the neck with fiberglass tape/resin. Been fine for a few months now. Is it caused by heat or RainX? I've always used RainX.
Discussion Starter #14
No rain x in mine either. I guess it's time to make my own. I like the PVC idea. Maybe just the neck, maybe the entire unit...
I never used RainX so I doubt that's what caused it. I think it more likely that they just used a poor grade of plastic.
I used rainx in washer reservoir, but only filler neck portion cracked on my 2003 Tacoma. It's not my daily driver, so fuck it! I probably do the pvc pipe on neck if and when becomes worse.:D
Discussion Starter #17
My 04 cracked and leaked out three years ago. Wrapped the shit out of it with gorilla tape. Has'nt leaked yet. Maybe toyota should make them out of gorilla tape
^funny
My Tacoma is a 2000 but even my '78 Scout never had this brittle POS plastic.
Making my own sounds like the best way to go. PVC neck at least, maybe the whole thing. I only want to do it once.
I did the PVC neck on the stock tank a long time ago, the OEM neck was shot but the tank is still fine today. I think it's because the neck is exposed to the engine bay heat while the tank is outside and cooled by the washer fluid.
The big OEM tank capacity is great, I think I've added washer fluid a half dozen times in 14 years. Keep it if ground clearance isn't an issue and the tank itself is still good.
Discussion Starter #19
Thanks Johnnymumbles
Reviving the dead... if you Taco guys can find the rear washer bag from first gen 4Runners, that seems to be a trick for the FJ80 fools who run ARB bumpers and lose the stock washer bottles.
So check into that; I bet you can find one or three at a junk yard; they're not in the engine bay heat and they're flexible plastic that was made to last a while longer than the stock 90s washer bottles.
I happen to have one or three in my shop at the moment as well... :D
1 - 20 of 20 Posts
