1 - 9 of 9 Posts
bent housing?
Big tars, little bed.
You sure it's not the driveshaft or axle shafts? Bearings? Chunk? Def the housing?
x2. i got some nasty vibrations when my carrier bearing and ujoints went bad.
It could be. I took the driveshaft to a shop to take a look at it. And then i think ill send the diff back to ecgs for them to take a look at it. And then spend the money on the housing and shafts if neither of those fix the problem.
Good to hear. I'll let yall know monday if it was this or not.
If its a vibe that came on that quickly, I'd more likely think its a u-joint.
I've changed the rear most joint 3-4 times, all my other joints are original.
It is so worth it to buy a joint from Toyota!
The auto parts store joints suck, if they can even give you the correct one. They are half the price but 5x the trouble.
I have a complete rear axle with 4.88 and an e locker with disc brakes if you're interested Parker
1 - 9 of 9 Posts
