1 - 10 of 10 Posts
I recently bought some 295/75/17 nitto a/t's and i am having some rubbing on the front fenders towards the back. i already did some cutting but i know they will rub off-road if i get into anything hairy. I was wondering if i could add any kind of body lift to my 3" Revtek lift with ease and safety? :confused:
TTORA SoCal
SO you got 17's which leads me to believe you have an 05+ taco, or an FJC. You can do a 1" BL and be fine, or just cut a bit more. Or you can see how much it rubs when you go out the first time.
One inch BL, but I wouldn't go any higher than that with a DD. Crap tends to come loose when you get into the bigger BL.
IF you don't take care of your truck...
now that being said. I've had a 2" BL on my 04 and it did cause issuse, just not with things coming loose. I hammered on the rig so it was to be expected.
Discussion Starter · #7 ·
t's not an '05 it's a '97. i am rubbing on the fender not the mount. from what i have heard here and yotatech sounds like the 1 inch will be tha way to go. local shops are trying to sell me the 3". thanks for the info guys!
truck ~n~ tow
I don't even see 295/75/17's on their site :confused: ... a 295/70 was listed... hmmm...
Why would you run bling 17's on an early Taco anyhow? :xsmash:
Anyhow... add the BL... it has nothing to do with a suspension lift...
Just don't go jumping shiat... and recheck yer BL bolts from time to time to be sure they haven't worked loose... You could probably get away with a 1" BL... and some serious hammer work... Or 2" if you want to do less fender banging/trimming...
1 - 10 of 10 Posts
