1 - 15 of 15 Posts
i looked and looked.. but couldent really find anything..
I was wondering on a 98 auto V6 4runner whats the most common front diff ratio? I have no vin... (lost the number) .. there was a sticker on the diff but that got ripped off. I will do the spin test tomorrow morning, just wondering whats common thanks
Retired
Probably the same as the rear...
Do you have access to the specifications sticker? Gear codes: http://www.tacomaterritory.com/wiki/index.php/Gear_Codes
The VIN is permanently affixed at 2 or more locations on the vehicle.
But what you really want is the axle code from the plate on the firewall.
Get the code and look it up.
this diff is going in my tacoma... i don have a vin or anything all i have is the front diff itself... is there any code stamed on the front diff that i can referance to something
Spin the gears and look at the side of the ring gear. Somtimes the ratio is stamped there.
most likely 4.10s
TacoJim said:
My door jam code is RZN171L-CRMDKAB
C/TR 045 FC40
A/TM
W59
How do I read this?? Is that a 4.56 gear and what does the C stand for. I have a 98 Taco TRD with Factory E-locker. 2.7.
you could only have OE 4.56s with the AT.
you most likely either have 4.10s with that year and the TRD pkg.
check for a BO__ code...probably BO3
grillmasterp said:
Just jack up the rear end and count the driveshaft:axle rotation ratio
color/Trim white - Oak?
W59 (automatic transmission code)
uh..W59 is the 5sp. ATs are 340s
1 - 15 of 15 Posts
