1 - 2 of 2 Posts
i have a 2001 tacoma 2 wheel reg cab long box 3400 series, i start the truck and put it in gear and or reverse and the truck quits it is an automatic any answers or hints would be a big help..
Not enough information posted to make an accurate diagnosis. If the engine stalls when put into gear, you might have an idle problem, vacuum leak, torque converter issue or even a problem with the transmission. Is the check engine light on? Try increasing the RPMs a little with the gas pedal when shifting and see if that prevents the stall. Try shifting directly to L from N and see if that helps. You might also try shifting when the vehicle is rolling or the rear axle is up on a lift or jack stands. That will help narrow down where the problem is at.
1 - 2 of 2 Posts
