RR Diff Lock Problem
1.6K views 6 replies 4 participants last post by  kchate5
#1 ·
I just purchased a 2001 Prerunner TRD and I'm loving it except for a small problem I'm having when trying to engage the locker. To engage it, I stop, put it in neutral, press the RR Diff Lock button, then proceed slowly making easy circles. However the light on the dash continues to blink. It seems to be engaged because the truck doesn't turn the same as it normally would without the locker engaged. So how do I know for sure if it is engaged? Can I get the light to stop blinking?
Thanks.
#2 ·
I've never had that problem but try not putting it in neutral. I have never done that and I don't think it said anything about having to put it in neutral on that goofy door sticker that I took off. Also try engaging it and then driving straight. The only time I've had to turn with the locker is to get it to disengage.
#3 ·
No reason to stop and put it in neutral to engage the locker. Try driving in reverse as well if it wont engage driving forwards. You'll know if it's engaged because the inside tire will slip when you turn. Also if you havent done the grey wire mod, it's an easy mod that works.
#4 ·
you dont need the grey wire mod on a prerunner...
#6 ·
Oops...didnt check the folder.
