21 - 40 of 106 Posts
Discussion starter · #22 ·
This is exactly what I have read/heard. However, one shop I talked to said to NOT use ANYTHING. They said they don't like to risk any type of lube spinning out onto the clutch disk and contaminating it. I still greased the splines very sparingly when I did mine.
I have never heard to use anti-seize, though that doesn't mean much...:p
In a sense, that shop is right. But, a very light coat won't hurt anything. This is the same reason you wanna repair a rear main, bc once that oil gets on the clutch disc... its ruined. The problem w/ greasing the splines is that some people are too stupid to understand what a light coat means.
^^x2 Great write up!
QUESTIONS - Should I replace my steering rack - since it looks super easy to get to, and I need to anyways? I have a spare one with new bushings sitting in the garage? :confused:
ALSO: The rear main seal - what do you use to tap that back in? My manual says SST only....(fuck that) and I definitely don't have a socket that big....LOL....
okay, back OT....
Okay, few more pics. Keep in mind this isn't my D.D.....(for now)..so the reason it is taking forever - is because I could care less if it sits for a bit.....LOL...
Picked up a new clutch-slave from T.G. (yea, yea - it was better than e-bay).
They got it to me in like - 3 days. I was really impressed.
Marlin is sending me the shifter-bushings, haven't received those yet.....
Here is the old "Release" or T.O. bearing....It was fucked!!! It reminded me of my old 1" skateboard wheels that sounded like gravel rattling around in a tin-can.
Here is the HF cheapo Blind-Hole Puller - that worked great! :D Picture was right after I pulled the pilot bearing...
HF blind hole puller:
That is where I ended tonight (very short)- because I forgot to order my Rear MainSeal......(I was even at Toyota today for the new Taco). Fuck!!!! :D
I saw no mention of this seal thing (pic below)? Please don't tell me this is something I have to order from Toyota.......
Also - which way does the clutch go on? Fat side with the most springs towards the engine or trans??
Also - greasing the throwout bearing - I know to grease the parts where the clutchfork touch, but what about the inside? Or the mouth? I'm not sure what exactly to grease there??
My chilton manual is a useless POS.
No one????? :confused:
So, I guessed that the larger portion of the clutch disc goes on the flywheel side......hopefully someone can chime in before tomorrow when I have to bolt this bitch up????:confused:
I guessed on greasing the throwout bearing....I greased the inside very lightly where it rides on the input shaft.........I greased the input shaft what I think was very lightly....."very lightly" is hard to determine over the intranet.....maybe someone can chime in on the pics. I greased the outter portion (obvious) where the clutch fork arms sit.....then greased the inside of the clutch fork where the ball sits, and the ball itself....hope I didn't miss something.
I also used red loctite on the flywheel bolts, and the clutch cover bolts.
Use the loctite sparingly, as mine seeped out of the bolt holes, and onto the flywheel. :(
I still don't know what to do about that stupid piece of rubber/gasket thing in the above pic. :confused:
I feel like I've been talking to myself here....
greased shaft:
greased splines:
Flathead craftsman normal screwdriver fit perfect and held the flywheel for torquing:
that almost just looks like grease crud.... i dont remember there being any seal on my inspection plate?
Discussion starter · #29 ·
Hey Trevor,
sorry, I've been MIA today. I can call you tomorrow if I don't make myself clear on here. As far as the shit build up on the inspection plate, just clean it off and bolt it back on once you get the transmission back in. I think it's a combo of clutch dust and some kinda foam isolater they put there from the factory.
From what I can tell on your input shaft splines, they look good on the greasing. I use just enough to give it a little sheen/shine. Your clutch, if I'm understanding you correctly, you're asking if the side that sticks out more goes towards the flywheel/engine side of things??? Yes. The "flat" side goes towards the transmission. The bad thing is, I've seen some aftermarket clutches where both sides are damn near the same and it's very confusing. The best thing to do is pay close attention to what side the flat side is on when you pull it out. Again, the flat side should be up against the pressure plate when you pull it off. BTW, my slave on my 4Runner came off eBay and I paid $15 ;). It's Aisin as well. That's neither here nor there at this point.
Excellent idea on the screw driver into the flywheel tooth deal. My hands were fucking KILLING me after torquing all those flywheel bolts down. Talk about a bitch. I couldn't come up w/ anything in my head that would work well. Kudos to you for coming up w/ that. Sad thing is, I carry that same flathead in my 05' Tacoma in my tool kit, but I don't have 1 in my tool chest in the garage. HA! I'll be up for a while, so if you're still working on it and you've got more questions, just give me a shout. If you need me tomorrow, I've got physical therapy from 2pm-3ish and then I have a night class at 6-9... up until those 2 time periods I'll be sitting on my ass :D.
Oh yeah, and if you've got a good rack to replace yours, shit... go for it. I could be wrong about this, but you'll probably need a front end alignment after you change em' out though.
Thanks Wes!! Yea, my main concern was that foam thing....but since it's no biggie - I'll just bolt everything up tomorrow.
Yea, that aftermarket one from gripforce was much thinner than my OEM. I was able to tell though, and bolted it up correctly - so that's good to hear. :)
I did pick-up a clutch slave from Trailgear, and marlin finally sent the shifter bushings. :)
I was going to swap in the spare rack (that's what took so long) but after inspection - it needed new TREs...so tacotoy on here sent me new ones - I went to install, and noticed my rack was leaking! So I'm scrapping that idea and I'll deal with the rack later.
I gotta get this thing back on the road tomorrow - since the 06 DD blew another CV boot.....
Thanks for the help Wes!!
Trevor
Discussion starter · #31 ·
LOL damn man... 1 bad thing after another huh? Oh yeah I forgot, as far as the rear main seal, just put the plate the broad side of a 2x4 and use a mallet to just tap the seal into the plate.
The direction the springs on the clutch disc face depends on the engine type. V6 = springs toward flywheel
2.7L = springs toward pressure plate
Nice job with the screwdriver trick. I do the same thing. Works like a charm. Everything else looked good so far. I couldn't tell for sure, but make sure you have a decent amount of grease on the fork ends where the TO bearing pivots on the fork.
anyone use the grease trick to get the pilot bearing out? its free and takes about 2 minutes. i just use a bolt from the bell housing and fill the backside of the bearing with grease and tap the bolt in the center and it popes right out.
Tell me about it!! Man....not a good past few months with me and autos....
Thanks ShowStop - I didn't use very much, so I will throw some more on there right now. I took off early from work to get this thing put together tonight.
The grease trick with the throwout bearing does seem like it would work good. I just figured sometime in my lifetime, I could use the blind-hole puller again - so I picked one up. It was cheap.
On the rear main seal - oh man, I forgot about that. I thing I used too much gray RTV.....It speewed out the sides. I forgot to get you guys' input on that....pics below....:(
Rear Main Seal:
Removal - used a punch and BFH:
Cleaned up area with brake-cleaner and a wire brush:
Flat piece of wood and BFH to tap back in (make sure to tap evenly):
The part I am unsure of - amount of RTV I applied:
I made the mistake of not torquing this down with a torque wrench either. I just hand-tightened, and may have tightened too much since the RTV speewed out the side.
I also RTV'd the bottom - but didn't get a pic. And also RTV'd the corners of the oil pan area real good.
Sounds good. The bolts are only 9 ft-lbs torque, so good-n-tight with a wrench should have been fine. The RTV pushed out is a good sign. Did you swipe the inside of the seal with some GP grease before you installed?
Good deal! I'm glad I don't have to take the Main Seal apart - LOL....
Yes! I did swipe the inner portion of the seal, and put the grease on the crankshaft...
Very good. Usually after I dab the RTV on there, I smear it flat and even with my finger. But to each his own...
SHIT!!! Where did the wiring harness rest at? I have the tranny up and ready to bolt in - but I forgot about the harness...LOL....Did it run all the way along the top from the engine all the way back? Or did it run along side towards the bellhousing, and then go up?
I guess I have to drop the tranny back down....
Wiring harness installs after you attach the trans. The main harness bolts to the bellhousing right above the slave cylinder. From there it travels down the driver side and bolts to the top just above the clutch fork. Then, just behind the clutch fork the harness splits. Once harness (with the o2 sensor connector) hops up and over the trans right in front of the shifter. The rest of that harness then plugs into the reverse switch, 4WD switch then finally the speed sensor at the back. The other harness keeps travelling down the driver side of the trans to the 4LO switch and shift of the fly transfer actuator (if you have these).
